Mugabetown - Whoretownin' At It's Worst.
Very difficult situation over there. The one that will affect us more is the decision in mid October about the US debt ceiling.
The last time they f**ked around with that they had their credit rating downgraded which has serious knock on affects. Cant imagine the chaos if the US actually defaulted on its loans lol.
In terms of AUD going up against the USD bearing in mind the economy is being propped up by the resource sector the stronger the AUD is the worse it is for us in the big picture. Anything going badly over there is going to reflect the same on us.
Very difficult situation over there. The one that will affect us more is the decision in mid October about the US debt ceiling. The last time they f**ked around with that they had their credit rating downgraded which has serious knock on affects. Cant imagine the chaos if the US actually defaulted on its loans lol.In terms of AUD going up against the USD bearing in mind the economy is being propped up by the resource sector the stronger the AUD is the worse it is for us in the big picture. Anything going badly over there is going to reflect the same on us.
Qft
I'm ordering from Summit Racing tomorrow :)
it wont last.
Is just a short term and Im confident they will seek bridging finance in between to reopen the Government operations
will have an impact on markets worldwide that's completely natural reaction.
should not have any significant impacts on majority of the Australian public (unless you solely invested in US dollars)
I do feel for the public servants that will not be paid though for that period - again will just be a time lag
Apparently but doubt it'll go that far, not a lot of rain just a f**k load of wind
very windy over here too. but no storm. although I can see via the radar some rain on its way
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
