Mugabetown - Whoretownin' At It's Worst.
moaning all. living in the northside is sucking at the moment.
nothing but dramas with housemates. think i picked the wrong housemates.
made current housemates an offer for me to leave if they can find a friend of theirs to replace me. just need to locate some blank a4 paper to print my letter and leave it for them to respond.
i sense another move is on the cards.
Where on the north side are you?
Missus is in property management so depending on where you are may be able to provide some assitance.
That escalated fast!
Every now and then, you come across something amusing in cases. The following happened when an employee was summoned into a meeting. Essentially meeting was an ambush to dismiss him. This is the employer's version: "Mr Hara says that Mr Morton turned up on 5 February 2008 in casual clothing, refused to discuss the various security concerns which Mr Hara wished to raise and said words to the effect that he had a "ball-brushing offer" he had to go and sign and was thereafter escorted from the building."
So much for planned ambush meeting lol
not good mr benno not good at all.
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
