Mugabetown - Whoretownin' At It's Worst.
Mikes 33 was only 40kgs more than my 32, that being said the 32 would drop a bit of weight with a gtr bonnet, do 33s have an aluminum one from factory?
also, windows phone.
the 33 drops weight too if you put the GTR bonnet on it.
I've played with windows phones, haven't liked any also a lot of my apps I use not available on windows phone...
You must have the optional extra bag of sand or somthing! Mine were about 95kg apart, but the 32 did have a GTR bonnet and the R33 did have an A-LSD
I have loved both of my samsung androids and I hate my work Iphone/Ipad with a burning passion
Yeah I had an LG "smart phone" when they first came out but it was crapper than crap! I then got a HTC Desire HD and liked it then the HTC Velocity and like it - Short of a couple of little hiccups they have been good, reliable and not broken (ok the Desire HD screen is broken it landed screenfirst onto the corner a concrete thing you find in carparks so you don't drive through it then half kicked/stood on as I continued to trip over - But it still works!) contemplating an upgrade because when our phone bundle contract is over will be the same time we are moving into an NBN only area and therefore need to change the bundle anyway and don't really want to go on a BYO plan because I was screwed over by optus with the insurance on the BYO plan which is why I made the switch to Telstra, optus charged me the insurance then said nope BYO phone so we don't cover them at all but if you give us another $600 we will fix it (I WAS ON A BYO PLAN AND BYO INSURANCE FROM THE START)...
That's a big sentence. BREATHE MELLY BREATHE! Lol
The HTC one is apparently good. But I will say Anna swapped from a desire hd to a Samsung s3 last year and was an instant convert!
drops further weight, if you put carbon doors, boot, roof............................shit carbon the whole damn car!
Summary - Optus sucks, I like my HTC.
My response - Optus are monkeys. Virgin mobile are awesome :)
http://www.virginmobile.com.au/htc/
i have the htc one, is nice feels far higher quality than the samsungs. dat metal vs plastic.
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
