Mugabetown - Whoretownin' At It's Worst.
Ok. Its 5.39am and I have been awake all nite.
You can only guess why ;)
On the 2 October At 11.54pm Jemma Louise Stephens was born with all limbs and only one head, weighing in at 4.035kg and 50cm long.
My wife Jannica completed her second 100% natural birth and I am so, so, so, so, so very proud to have an strong and beautiful wife. I love her to bits.
We only got home about 20mins ago or so pretty rooted since got f all sleep the night before and zero sleep last night / today.
On another note the Ant-Eater was finally unleashed on the dyno yesterday :banana: after I met with Sean early in the morning.
Car has made a healthy 470hp on 98 pulp at 22psi. Am very happy to say the least with that result considering only jut run in tune.
I will post more details up soon after I get some much needed rest.
I was due to drive the car today but thats not gonna happen. As some of you have predicted, when it rains, it pours at my end.
This reminds me, Clint I am going to ask you a favor for me and will text you details.
As you can appreciate I will now be going to bed with some much needed rest with my family.
So now, you will all have something to discuss and make your Thursday just that little more exciting and special.
Talk to all of you guys later,
Anthony & the family
Somone better answer that phone.....because I fcuking called it.
Congrats to you and your Wife Ant's.
I have the details and will take care of it for you.
Get some sleep and enjoy the new little one
Congrats Ants stoked everything is going well on all fronts :-D
in other news. An ERD built white 32 is for sale mmm. Might have to put my low ball hat on.
Is it desteros old car? Big single on it?
I always feel awkward watching someone tune my car. Feel like my presence there makes them feel like I'm standing around rushing them wanting my car finished. When its actually more excited/intrigued about it
QGC gas fields south of Chinchilla.
CSG is SATAN!!!!!!!!!!!!!!
Congrats on the newborn Anthony! That is sensational news.
Oh yeah, and the car. Congrats on that too. 470 ain't bad for a run-in tune :)
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
