Mugabetown - Whoretownin' At It's Worst.
Doesnt he know car club friends come first!
When do we get promoted from car club friends to real friends?
I'm gonna say when you've achieved one of the following:
I've slept/passed out on your floor/with you on the floor lol
I've shirts off man hugged you
You've received >5 drunken phone calls from me
Probley other reasons but those spring to mind
Interesting friendship parameters. I trend to think its a good thing Nick doesnt have my number lol
I'm worried that he has mine...
Mike and I have never done any of the aforementioned topics and we're mates. Same with McFly, Scott et al
Yeah, we won't ever be real friends...
This I agree with...
I dont think I want to be your friend if thats what it takes to qualify
This I also agree with...
You should be worried Tony, very worried... Might want to get that number changed :P
RNA on the 19th
I am keen! However I have a bday dinner that evening so I would have to get intoxicated and eat pork knuckle between 11 and 4:30ish meant to be at Woodford by 5 but already said I will be there late... However if there a bunch of keen people then that is ok, I can just bail early...
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
