Mugabetown - Whoretownin' At It's Worst.
Didn't know you had a photo of my dad
Your dad's a meme? Awesome!
In other news, was looking at the DS forums. Interesting to say in the least. There's a guy who's built the motor in his Mazda 6 and supercharged it. He's pulling 160fwkw.
From a built, supercharged 2.4L motor!
the 2.3 turbo from the 6 mps?
would have made more power too, surely?
That's the one. Can get the same engine from the 3 and 6 MPS Oh and the cx7 too. Can Make 200kw at the wheels pretty easily
He should've just bought an MPS! Awd as well.
Are they 2.3 or 2.4?
2.3
Well that is shit then. The stock turbo engine makes 190kw. Which wouldn't be far from 160kw at the wheels.
That's a lot of boost for sfa gain.
No cooler because no space apparently. :/
Toying up the idea of supercharging the maxima. Run about 5psi...
Spent all fkn day putting the front bar and lip on.......I forgot how diddly this is and also understand why a lot of peps choose the easy way and just trim da farker.........
But all done now
    • Jax Tyres this Monday morning. Front lifted 15mm Back lifted 12mm Quote1, $175 per tyre + wheel alignment. Quote2, $660 inc wheel alignment. paid $298 for the lot.
    • Finally have an update on this  Rack came in this week so I did a test fit. You do need the S chassis bushings since the rack is 5mm thinner than the R33 rack. The main issue I foresaw and ran into was one of the hardlines not lining up properly with there it's meant to on the rack. After some gentle coercing and bending very slightly, I managed to get it to fit without any kinks and keeping the hardline pretty much in all of the factory mounting positions. I did have to unbolt all of the soft mounts to move the line around so I could snake it out and bend it safely but it looks good to me for now. I'll update when the rack is fully bolted in and functioning.
    • I hear this thread needs an update following its adventures last Wednesday!
    • What are you thinking makes a sequential shit to drive on the street? About the ONLY thing I can think of, is if you're wanting to be able to roll up to lights in third or second and pop it straight into neutral, or you want to come down two or three gears, say out of 5th and back to second, but they shift quick enough it doesn't really matter
    • I'm not a drag racing guy, but that was a good watch. Didn't Ibrahim's car have some cooch! But the big question is....WTF is with so many of them running without seatbelts!
