Mugabetown - Whoretownin' At It's Worst.
I see him trawling this thread as we speak :yes:
Interested to see what results we all get. There is another guy on here that just got his results back on a very very similar setup to what mine is. It made 480rwkw's on 27psi. 6466 with .84
Was he running E85?
Yep..
Here is all is....
That was my car.
Couldn't go past 27 due to needing to up the breathers on the rocker covers and mainly from frying tyres on the dyno
My main thing was that i wanted it be strictly streetable and wasnt fussed about the dyno figure - not that its too bad at all! Therefore I went for a 6466 with .84 twin scroll - I was concerned this would be too big as I was thinking to go for a 6266 originally - although very happy with this setup which is super responsive compared to most cars I have been in, not to mention torquey-as down low due to the RB30.
It has been running for some time on 13psi run in tune which it did 308rwkw on pump 98 - then 20psi on e85 which it did 365rwkw for about 2 weeks.
Even on 20 psi the car is a wild drive on the streets - stepping out in 4th gear once is hits about 4000rpm as if it was second gear (still waiting on half decent tyres to show up).
If I upgrade the catch can (which is small as I wanted it to be hidden) they could push 34psi but doubt I will ever need to, nor bother going to the troubble as this thing has been in the making for over a year now!
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
