Mugabetown - Whoretownin' At It's Worst.
Yet the wedge still chops the a-bomb
Since Nick isnt here I will reply for him. The A bomb ran a faster quarter and if even if the wedge is faster from a roll on its only faster *Mysterious music*......for now
Haha this kid knows me well lol
This may be true but has Martin spent as much money as nick has on the wedge?
It would be pretty close, Both have had a engine swap, Nick would have spent more on the gearbox, Martin would have spent more on the turbo, computer ect
McFly can just up the boost in the Wedge though. What can Nick do?
Nothing and this is why martins car will always be faster than mine and he definetly should kill me down qrs main straight with roll on power of the rb
I am not defending Nick. I am simply stating Nick and Martin have likely spent similar money. And no it isn't always as simple as turning up the boost and pissing power.
Mines owes me about 25k totall including purchase
I didn't mean it like that but yeah. My main qualm with natros, especially high comp natros is that there isn't anywhere furthe that you can go. :(
Has anyone gone spastic on a natro vg motor?
I know there's one that races modified production that's fairly quick and they have a lot of restrictions
A couple, but not many. Was talk of a crazy one in the US but no results. Most basic Aus builds hover around 150rwkw. Not surprising really when a stock TT makes ~180rwkw. And you can buy them for about $2, and they drop right in.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
