Mugabetown - Whoretownin' At It's Worst.
its good mate. So pleased to have them all at home.
Back at work today, so can't play much with GTR nor spend time with my little one :(
But need money and so does my boss which is totally understandable.
Fair enough! Hopefully you get to spend some more time with them both soon
Ants, double your C/O rate. :D
although it would increase my salary quite attractively I would never be able to be profitable if that ever happened.
But I know where ur comin from ;)
So one of my "mates" has decided he now wants itbs... Looks like I won't be going down that path, f**k he's an asshole, as soon as he finds out something's going to be better then something he has he shoots out and buys it.
f**king sad little wanker
long runner Itbs out the bonnet? Aww yis
There is only so many ways to skin a cat, who cares if he has some things the same as yours, its bound to happen.
Yer I know, lots of people end up with similar setups. I dunno a dislike of a human can throw reality out the window mr bunts :)
what is it with qld tuners and not being able to tune a car in a timely fashion.
i want pics and results damnit.
It is being done in a timely fassion, Do you know anyone in NSW that can do all the fabrication work on a new engine fitout in under a day as well as source and fit other required goodies? Our initial expectations and timelines were more optimistic than reallity in relation to this project. Still progress is happening and long weekend is now over.
Can he afford it, and can he get it done. If not then what's the problem let the dreamer dream.
He can't afford them but he'll get them, he's 22 still lives at home and gets his girlfriends to pay for EVERYTHING.
He just ordered a set of 18x13 -28 work Meisters, cost him something like 4k :O
.... Mayb he sells drugs
Steal his rim's...sell them buy your gear.
What car is this in/on?
i was under the impression the fab work was all done, and just awaiting a tune?
Look at it the other way. You can do a better job and show him up/
some people just like to stir shit and make it seem as though there's an issue.
Good things take time.
lame. Beats my 18x13-6's
    • Thanks, I'll shim that plug and hopefully it fixes it.  Yes still factory turbo for now, still have the misfire it's not as bad but still noticeable
    • I had someone check the CU, they said it was fine but it could be buggered  I was only running around 7-10 PSI on the dual stage controller, but my boost gauge is shit house and needs replacing so I'm not getting a true reading.  Then I ran from wastegate pressure as per Turbosmart but still have the same sort of issue
    • Yeah this is a thing. I've had mine setup like this for a few years now, works fine. If I dredge my memory bank, I think I had to do this after I removed my factory dash.  So you've tried it on gate pressure, I'm assuming this is the factory turbo? Did you still have misfire issues with that setup?
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
