Mugabetown - Whoretownin' At It's Worst.
There's a really nice stealth black R32 in engine bay picks section with powerglide. Have been weighing up options and this approach for something for quick street/drag. Wet clutch, torque multiplication and transbrake for drag would make for a very interesting launch, if the theory meets the real world. Fingers crossed :)
there was a 500kw 32 in town that had a 2 speed in it, but i never got to go in it. had about a 5500rpm stall on it
then again getting hi powered rwd off the line cleanly is all in the launch control/suspension setup and how much rubber you can stick under it
lol look at the advice google gives you on that
also #@Beelzebub89 one for you, go into google on any computer and type in do a barrel roll and press enter.... watch google chuck a fit hahahah
So true. Set up will be drag orientated, but engineered. I get a pretty good supply of used Michelin race slicks from Porsche Cup car. They aren't totally gone, approximately 50%, but won't be using these on street - they are atrocious cold and HWP don't tend to see the positive traction side lol
What do you mean? Hwp love seeing racing slicks on imports on the street. They love that sort of behaviour. :P
On that note, morning all!
Cost/gain analysis - $50 each and no drag bags slapping into arches/guards and better grip than semis
They will have worse grip than streets let down to 20psi. Been there done that, it doesn't work.
On 18" qualifying tyres? This hasn't been my experience.
Yep. They have no side wall and no bag and most of them have seen too many heat cycles too. Good for circuit terribly shite for drag racing. A good set of drag radials picked up .5 of a second in the 60ft. 2 seconds down to 1.5.
The lesson I learned from all this is to use a tyre for what it is built for. If you aren't you are pushing shit up hill.
What a lovely day, and tomorrow is Friday :D
Tis a nice day. I am outside for half of it too. I do have to audit a fish processing plant though. .. bit worried about that, walking past the fish section at coles makes me gag
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
