Mugabetown - Whoretownin' At It's Worst.
Yep. They have no side wall and no bag and most of them have seen too many heat cycles too. Good for circuit terribly shite for drag racing. A good set of drag radials picked up .5 of a second in the 60ft. 2 seconds down to 1.5.
The lesson I learned from all this is to use a tyre for what it is built for. If you aren't you are pushing shit up hill.
So what you're saying is that you've back to back tested these particular tyres?
And the results show that drag radials had a higher coefficient of friction than slicks?
I told you the real world result just before. .5 of a second over the 60ft shows a big difference. You can use what ever you want, I never actually gave a shit
What do you mean? Hwp love seeing racing slicks on imports on the street. They love that sort of behaviour. :P
On that note, morning all!
Cost/gain analysis - $50 each and no drag bags slapping into arches/guards and better grip than semis
Morning all
Morning
Morning guys :)
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
