Mugabetown - Whoretownin' At It's Worst.
just so we are clear, you are aware of the following because of the height difference.
Intercooler pipes wont fit, need to be modified.
exhaust wont fit, needs to be modified.
stock turbo is too small chokes HARD at ~5500 (you end up with about 80kw@ wheels by 6500)
intake pipe will need to be modified unless stock/flexible ish
front strut brace is unlikely to fit
car it came out of was probably automatic, dont forget to change the spigot bush in the crank or you will f**k your input shaft bearings in the gearbox
retaining vct isnt hard, just needs some bundy tube and some patience to run the line from the oil pressure sensor feed.
probably some other things i have forgotten since doing it.
im sure there is a RB30 build thread somewhere that he can follow tits.
Also in case your not aware already
Zac is a mech ;)
One way so solve a lot of thoes, 26 head ;)
There is threads and PDFs and a mountain load of info on them I think I should be pretty right to tackle it. No doubt I will encounter issues but this is a learning experiance and training for me, and not sure on if it will be going in mine or getting sold, ATM if I sell it Kathryn's had already chosen what the money from it is going towards
that only fixes 2 of the issues, strut brace and VCT.
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
