Mugabetown - Whoretownin' At It's Worst.
One way so solve a lot of thoes, 26 head ;)
There is threads and PDFs and a mountain load of info on them I think I should be pretty right to tackle it. No doubt I will encounter issues but this is a learning experiance and training for me, and not sure on if it will be going in mine or getting sold, ATM if I sell it Kathryn's had already chosen what the money from it is going towards
Biggest tip - buy a Dremel tool with metal cut blades. The timing gear is a real c-bomb to get off - cut through the key way first and opposite side second and when almost there crack the final bit by prying apart. That way you won't nick the crank. I know someone wrote about this on SAU, but what they wrote doesn't go far enough.
Can you post up a link please :)
hi guys i have other things i want to get done soon so im looking to sell my car as many of you that have followed the build know there havent been any corners cut here its all the best parts and car is set up ready to go.
have hardley driven it to be honest and its part of the reason im looking to off load it, its doing nothing sitting in my garage week after week and i want to travel next year.
feel free to ask any questions via PM on here, or email me on info[@]isurrounds.com.au
looking for $ 30,000 firm
details :
Engine:
2.3lt stroker motor
Manley knife edge billet 100mm balanced crank.
Wiesco hd1400 pistons 9.0cr
Howard's ultimate duty billet I beam rods upgraded arp bolts.
Acid dipped block honed and decked
New Walsh plugs.
AMs balance shaft delete.
Ported valve thoats
1mm oversize super tech valves
1mm oversize super tech black exhaust valves.
Super tech double valve springs.
Super tech titanium retainers.
Super tech stem seals.
Greedy adjustable cam gears.
Kelford 280 cam shafts.
Custom air box
Custom 4 inch intake
Custom oil breather catch can with speed flow fittings and Teflon lines.
Kiggly Hla oil pressure reg
New water pump
New oil pump
New gaskets
Acl race bearings
Map h11 head studs
Oem head gasket
Pwr alloy radiator
Custom inter cooler piping
Hdi hybrid inter cooler
Precision 6466 bb turbo
Jmf tubular steam pipe manifold heat coated
Turbo smart 45 mm hypergate
Custom screamer pipe
Turbo smart race port bov
AMs rocker cover plate
Custom sprayd rocker covering
Upgraded thermo fan
Clear timing cover
Gates racing belts
I'd 2000 injectors
Ams billet fuel rail
Turbo smart fpr 800 regulator
Mitsubishi fitting kit
2x intank wahlbros
Upgraded braided Teflon fuel lines to rail
Speed flow fittings
Upgraded fuel filter
Braided lines to reg and flex sensor
3 inch custom v band dump pipe heat wrapped
3 inch full straight through exhaust
De cat
3 inch muffler
Lightened flywheel
Quarter master 8 leg twin plate clutch with hydraulic release bearing and STM clutch cable
Standard gear box
Standard Diffs and transfer
Ohlins DFV adjustable coil overs
White line adjustable front sway bar
WhIte line adjustable rear sway bar
White line bump steer correction kit
Standard strut brace
Haltech ps1000 ecu
Haltech air temp sensor
Haltech oil press sensor
Haltech fuel pressure sensor
Haltech wide band afr sensor
Haltech boost solenoid
Haltech flex sensor
Haltech 4 bar map sensor
Haltech race paq dash display
Upgraded dba 4000 slotted brake rotors front with project mu pads
Upgraded dba 4000 slotted brake rotors rear with project mu pads
Enkei rfp1 black wheels 17x8.5. X +22
Federal rsr tyres
Carbon fibre boot lid
Standard boot lid
Recently fully serviced with all Diffs oil changed , gearbox and motor done
Motor has done 2,500 Kay's since build
Car was tuned by Powertune
501.4 kw @ 42psi
link to sale thread on Evo Oz http://www.evolutionoz.net/forums/index.php?showtopic=87686
Biggest tip - by a Dremel tool with metal cut blades. The timing gear is a real c-bomb to get off - cut through the key way first and opposite side second and when almost there crack the final bit by prying apart. That way you won't nick the crank. I know someone wrote about this on SAU, but what they wrote doesn't go far enough.
Yeah had to deal with this on a rb20 at the workshop
We cut and cold chiseled till it split
But this one has a bit of oil around if so I recon it will come off pretty easy
Also sprayed it with inox and will let is soak over night
RB30 are an absolute pain in the a - I inoxed and wd40d the hell out of the last three and still had to cut gears, even top line pullers wouldn't sit behind gear. I can't understand how they rust on the inside of a press fit machined surface??
That list of mods was like a tick the box exercise compared to my E3 - with exception of I have a better cooler, I also have block o'ringed and head receiver grooved and 290 by 11.5 cams.
you have too many crazy cars :P
I know, I know. I am seriously wondering whether OCD can manifest in car collecting :)
Thanks for your help on Sat :) I am looking into getting Hardrace components for the top camber arms. AND the Craziest has now begun :)
It's not press for they slide on and off pretty sure they might be a tight fit but I don't rember them being press
But if they are you learn new things everyday
It's a very tight fit - does have a keyway lock. Cannot understand how they rust there??
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
