Mugabetown - Whoretownin' At It's Worst.
My goals at the moment are a fully paid off house in 10 years time...
And if it's not paid off, It's because I've bought a second one.
if u are able to achieve that Marie, I will somehow find a way to marry u and become your trophy hubby
If my requests that I made at work are met in some way, it's actually 100% possible on my own to pay off my debt, save a deposit, and pay off a house all in a 8 year window.
Please note, I'm not aiming like so many of my friends to borrow to my absolute maximum and live in the most ritsy suburb like most of the people I know, who are all up struggle street and causing endless arguments with their partners. I'm looking to do it the smart way.
Buy a house in the $350K or less bracket, with a 20% deposit.
Yes, it will take some hard yards, yes it will mean not being able to mod my cars left right and centre, but 10 years from now, I'll have a disposable income.
But then again, my goal set may drastically change. LOL, but this is the current goal I'm currently working to, and I'm already clearing my debts with a higher repayment than what it will cost me to pay off a $500 000 loan in 30 years ;)
im looking to do it differently.
similar price bracket, but near on 50% deposit, because smaller loan means less interest to the bank.
Offset account also does this while leaving you with liquid funds in case of emergency or unicor being purchasable at the right price
sounds very positive mate. Theses days if u are able to be disciplined and save / make greater repayments towards existing loans, you can extinguish home loans within half the normal time.
Your last paragraph is probably the most realistic one as things will always change with some causing goals to also be changed. Whether they are positive or adverse in nature.......only you will know
but if the money is easily spendable, i may just spend it. easier if i cant touch it as easily.
It had flecks of what seems to be black tyre rubber/compound all over it and was pretty dirty. I am convinced its last outing involved two rear shredded tyres lol
by whom ;) ?
Debt shop. Move money around to lowest possible repayment figures. 0% credit cards and don't borrow anymore for a while. It reduces debt levels and increases good repayment history. Serviceable debt isn't the enemy, it's just people never plan for things like: what if I lost my job tomorrow.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
