Mugabetown - Whoretownin' At It's Worst.
So stock it even had the little plastic cold intake that goes to the filter box
Morning slarts, only pair of clean socks and I step onto the rug to feed my bird and the dog has pissed on it over night :/
That's even more disciplined. In management terms they call that Locke's goal setting theory. Essentially you set waypoints to getting things you want to achieve. They have another acronym too called SMART
Specific - there is a precise and clear statement of intended outcome.
Measurable - there are clear indicators (quantitative or qualitative) of whether goal has been achieved.
Achievable - The goal is achievable, within available resources and environmental constraints, and is compatible with other goals that have been set.
Relevant - the goal is aligned with broader goals, values and priorities, which provide a rationale for the goal.
Time-bound - The goal includes a statement of precisely when it is to be achieved.
Winning Mel :)
someone remembers their management principles well ;)
pls do tell us what the outcome is Marie
the outcome is I'm going elsewhere. f**k putting up with the rubbish that comes from this business.
Yes the business does good work for business, but it has farrrr too many managerial issues, and lately have gone well against my ethics with doing stuff for clients.
Not only that but I'm left to now do work that I'm not meant to do, because other employees who are meant to do it can't do it, yet they don't get penalised, and I do t get offered any sort of reward except a gold "f**k you".
I'm over it, it's stresses me out day in, day out.
For the past while I've had to put on a massive act that's stressed me out to no end, and it's not fair to me, or my friends and family who end up with me getting pissed at them, but my frustration is 99% built up from this job.
well at least you are doing something about it. Bet you they will turn around and offer you an incentive to retain you.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
