Mugabetown - Whoretownin' At It's Worst.
Ahhhhh the stealth approach, very sensible. I still haven't managed to come around to this approach - I actually enjoy arguing the police powers and road traffic act with the 50 :)
Life's more fun with a loud exhaust.
Worry about that when the time comes, the likely hood she'll keep it and do the swap is low (sorry kat but the odds are against you keeping it)
It takes a very very strong bond with a particular car to want to drop money on it when you know there is a cheaper route
It looked pretty clean in the photo Nick, if the car is straight it's worth keeping and just getting engineered. The shells are the same, it's really only the numbers that aren't.
Mine has a dint where the rear right hand pod goes, other than that it's straight. Seriously want over fenders thinking more and more how cool they look lol
Michael that is seriously worrying lol I now rank that in the same category as the gold shorts package I saw yesterday lol
Mostly because she loves taking it hard but she also has some problems...like rust.
Tunnels/mountain cuts especially :D
Got told my car didn't sound like a commodore yesterday, I guess that's a good thing
Tunnels...clutch in...rev-limiter...
It's still a commodore at heart.
You sure? I'd be checking that...
I assumed P platers can tow trailers, I'd check that as well.
You should be able to drive it to the nearest place for the purposes of obtaining registration.
This is correct, just organise CTP first then you can drive it to get a RWC then to the nearest Main Roads dpt.
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
