Mugabetown - Whoretownin' At It's Worst.
real keen to see the ant eater on the weekend :) are you totally in love with it? driven it much?
not too much.....think I did about a 100km since I got it back...........but yes it's great to finally have it.
Need to learn how to drive it all over again..........but jut feels fantastic Bodo :)
good to hear man, guess you'll be takin it easy at the laps of happyness?
well I'm not gonna ring it's neck that's for sure.
Will be taking it sensibly until I get my confidence back up................which is gonna take quiet some time
But I will get there in the end ;)
north side. just watching Scotts build, and hearing that Dan is building Matt's new engine
morning scott hows the car?
Still at All Star Tuning. Long story short is there is a few hiccups here and there with the transplant. Nothing major just little things here and there that need modifying as they foul on other parts etc. Heaps of little niggly things like that.
Last i heard was the E85 was eating away at hte fuel line a little so once thats fixed its ready to Dyno. Its full of water and oil and just needs the leaky line fixed.
I'm just throwing it out there, Colin, Beezlebub89, is a f**king legend! :D
Gidday Tony ma man.
Mine either!
Mine is... Now I am the odd one out...
Changing my pic won't help that tho...
Hello Mell :action-smiley-069:
Did I warn you of the little bits and pieces that just need a little work like I did zac? Having done it they are a dint as it's all little bits and pieces, none of which are particularly difficult to fix but take time and sometimes thing have to be taken back off to sort them.
There is a reason the evo is only going 2.3L and not the different block 2.4 route.
I always knew it was never going to be a simple change over. Im not worried/fazed at all that its taking a few weeks longer with these little things. Id rather it all be done right the first time.
  • Like 1
Hosting the biggest Amateur event in QLD at the moment and all these good young golfers think they are Tiger Wood or Adam Scott.. Hurts my head
Tell them their swing is awful Scottie and that they need to put more hip into it...........................for the lulz :P
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
