Mugabetown - Whoretownin' At It's Worst.
real keen to see the ant eater on the weekend :) are you totally in love with it? driven it much?
not too much.....think I did about a 100km since I got it back...........but yes it's great to finally have it.
Need to learn how to drive it all over again..........but jut feels fantastic Bodo :)
good to hear man, guess you'll be takin it easy at the laps of happyness?
well I'm not gonna ring it's neck that's for sure.
Will be taking it sensibly until I get my confidence back up................which is gonna take quiet some time
But I will get there in the end ;)
north side. just watching Scotts build, and hearing that Dan is building Matt's new engine
morning scott hows the car?
Still at All Star Tuning. Long story short is there is a few hiccups here and there with the transplant. Nothing major just little things here and there that need modifying as they foul on other parts etc. Heaps of little niggly things like that.
Last i heard was the E85 was eating away at hte fuel line a little so once thats fixed its ready to Dyno. Its full of water and oil and just needs the leaky line fixed.
I'm just throwing it out there, Colin, Beezlebub89, is a f**king legend! :D
Gidday Tony ma man.
Mine either!
Mine is... Now I am the odd one out...
Changing my pic won't help that tho...
Hello Mell :action-smiley-069:
Did I warn you of the little bits and pieces that just need a little work like I did zac? Having done it they are a dint as it's all little bits and pieces, none of which are particularly difficult to fix but take time and sometimes thing have to be taken back off to sort them.
There is a reason the evo is only going 2.3L and not the different block 2.4 route.
I always knew it was never going to be a simple change over. Im not worried/fazed at all that its taking a few weeks longer with these little things. Id rather it all be done right the first time.
  • Like 1
Hosting the biggest Amateur event in QLD at the moment and all these good young golfers think they are Tiger Wood or Adam Scott.. Hurts my head
Tell them their swing is awful Scottie and that they need to put more hip into it...........................for the lulz :P
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
