Mugabetown - Whoretownin' At It's Worst.
Was it needle or the gun? First time I got mine done I opened my eyes with the needle sticking out of my nose and passed out, second time was the gun and nowhere near as painful! Think no needle also helped lol
How on earth do they so it with a gun??
Yeah well I couldn't open my eyes cos they were all watery haha
Yeah I was like oh that didn't hurt too bad open eyes fuuuuuuccccccckkkkkkk *pass out* the gun its just like the clamp they used for the needle but attached to the gun not put the needle in it was quick and didn't swell like the needle one did
Can't get a turbo for another 2 years :(
Matt, I would look for a non turbo auto like what Kathryn did. I keep saying it, they are the exact same shell. You can instantly upgrade brakes. Nobody can tell the difference unless they FAST the chassis. Once off provisional then upgrade engine and gearbox from a wrecker like Skyline Spares (they courier to QLD), it won't cost an arm and a leg to do and you can always transfer it back should your licence be revoked and you go back onto Ps - worst case scenario. I would recommend an R33.
It's not worth the cost. Buy NA for $4k, spend $3k getting it legal and fixed up, total at$7k.
Buy turbo for $5-6k, profit.
They're on their ps! They should be forced to drive NA's like I had to... These exemptions are BS
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
