Mugabetown - Whoretownin' At It's Worst.
http://tmr.qld.gov.au/Safety/Vehicle-standards-and-modifications/Vehicle-modifications/Light-vehicle-modifications.aspx
VSB - 14
Open document and scroll down to a PDF link entitled: Section LA - Engine. This is TMR legal mandate for modifying cars/engines etc in QLD.
They also explain at the bottom why P1 and P2 are in their mind limited to non- high powered vehicles.
You've disproved your argument right there. It clearly states that if an engine that is 120% (or more) powerful than the factory fitted option, certification is required. RB25DE = 200hp RB25DET = 250hp. Clear difference that is greater than 20%.
I was actually talking about NSW. I posted above for others to view after looking into qld for you. I can read :whistling:
Dot point 2 of clause 1.1 leaves some scope for argument. I went to conference about all of this and they are seeking to nationalise. It can be done in QLD, but may require certification depending on precedent about aforementioned point.
8.1?
Who do you work for any how long have you been planning?
Brookfield Multiplex I'm a site engineer though not a planner i just do all the programming for my zones. Only use p6 for the contract stuff all my other ones are on suretrak 3. Been doing it for about 3 years.
Who do you work for?
For the record - looked up law for you after my initial posts. TMR don't make the laws, they simply interpret them and most importantly these laws are constantly changing. Law never stays still.
I never expressed an opinion on whether it could or couldn't be done. Simply posted the relevant section where all answers are found for Qld. I was trying to be helpful.
However, there is the above clause and section to seek an engineer's opinion on.
Ah I see. I've worked for Downer EDI (engineering arm) for about 8 nearly 9 years (5 as a planner), then BMA/BHP as a senior project controller, now I work for a consultant company, currently working on TMR flood portfolio
Sup All, need less sand in vagina's in here.
Can you do it...yes
can you legally do it...maybe
can you do it on the sly...yes
can you get away with it...not likely
All sorted now on to important things.
Early day, and Telstra issues resolved quick smart. Best indian call center person I've ever encountered. A little hard to understand but very helpful, and actually listened and agreed......crazy world
it is only a matter of time Bodo before call centers and the like become more effective and efficient.........and then charge just as much (if not more) than if it were performed in Australia.
will be happy days?
Just don't go shoehorning a 911 NOS fed turbo engine in there :)
or this http://www.youtube.com/watch?v=u_RCsx63UiI
I was thinking more like this
http://www.youtube.com/watch?v=sncE-uw1onE
keep it drivable :) 4play manifold ftw!
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
    • Well, I was using ECUTalk software if that helps? Not sure if that only can see engine codes? Is there any other software I could give a try? Or any way I can get a blink code?
    • I never touched it, it should have. I'll try to give it an adjust. With IACV plugged in, it idles at around 1120RPM on average. Max 1200 RPM, Minimum 1025RPM before it starts dropping right before stalling. Took the data from the Nistune logs.
    • Thats what im trying to solve bro  no one with aem tuner experience would advice  much appreciate
