Mugabetown - Whoretownin' At It's Worst.
Working on the idea of a gt30 but not high boost
high flow from hypergear will be cheaper in the long run, bolt in with less issues and give better response with the power you want. a 3071 is a 270ish kw turbo, will be a bit laggier, and requires custom dump and some other bits to bolt in.
Just built Pls R34 engine. Fully built Nur block .5 ob nitto internals with a single GTX3071R runs EFlex 389awkw. On the cheap, all fitted tuned etc 40k exercise. Fuel system alone was 11k. Engine and fuel system capable of 600kw +, but turbo limited to 22psi and at max flow.
this rings the bell mate.
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
    • Wow! how times change 2017 $15k seems expensive... now $30-$50k is the price.
