Mugabetown - Whoretownin' At It's Worst.
Working on the idea of a gt30 but not high boost
high flow from hypergear will be cheaper in the long run, bolt in with less issues and give better response with the power you want. a 3071 is a 270ish kw turbo, will be a bit laggier, and requires custom dump and some other bits to bolt in.
Just built Pls R34 engine. Fully built Nur block .5 ob nitto internals with a single GTX3071R runs EFlex 389awkw. On the cheap, all fitted tuned etc 40k exercise. Fuel system alone was 11k. Engine and fuel system capable of 600kw +, but turbo limited to 22psi and at max flow.
this rings the bell mate.
    • Yeah, Duncan is helping sell me back to Android devices. I've hated the whole Android head units due to their speed issues. Even in my old Hyundai Kona (2022 model), it behind the scenes was Android, and slow and shitty to start up. Once running wasn't bad, but still a good 15 to 30 seconds.
    • My roof rails are off atm on the E39 until the rust is fixed. I did find another little bit of surface rust under the rails when I took them off. As @soviet_merlin said I'd just leave them alone unless you're planning on ensuring they're properly sealed. I was on the fence about leaving them off as the delete is still a thing in BMW E39's but I feel like the car is missing something (er, it is, der) with them off and I'm looking forward to putting them back on.
    • Man, I miss having a phone that fits into my hand!
    • The speed this thing starts up is making me want to replace my old one. Though my old one immediately kicks into reverse camera as soon as reverse is engaged, it's clearly not part of the android system. For everything else though, starting up, connecting to hotspot, opening maps, starting music in spotify is easily a ~2 minute affair.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
