Mugabetown - Whoretownin' At It's Worst.
yep. all done by benchmark, the boost has come on earlier since the weekend you were here when i was installing the new wastegate actuator, 3rd gear seeing peak boost at ~4100 and 4th gear is ~3800
ants, there are no vids of my car being tuned.
That's incredible and the lines are pretty smooth too. It comes on strong early - good match on turbo.
Nah, buy something with a 13b Bridgeport, much more fun :)
Can only have a 12a on your ps. I've said it before and I'll say it again if you want to go fast on your ps but a te/tf cortina and bomb the f**k out of the 250 cross flow natro style. There is two doing 11s in qld. Street legal p plate legal 11s!!!
... P players are idiots
  • Like 1
or have a license from Canberra, no p plate restrictions.
I try to be responsible but sometimes I just wanna be a kid :P
Practice won't be to hard, just gotta remember I have more kW then the rolla haha
Just go out whoop whoop and chuck skids and be a model citizen in town it's that simple. Nobody sees it but cabbage nobody hears it but the crows.... But the lines, that remain for the ages :devil:
Escort, 2l pinto twin 40s or 45s on it. jobs a goodun. 150-170hp atw a lot of people getting 200hp out of them with headwork these days. Strip it bare and drive it into the ground.
  • Like 1
    • Did you take the MX5 for a Blat around the Track at all?
    • LOL, "they said it might be slippery"..... 30 seconds in your off, 60 seconds in white twin backs into the corner That new track looks good, and the Datsun was chopping cars quite nicely
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
