Mugabetown - Whoretownin' At It's Worst.
Stupid comment of the day goes to... Matt!
You don't need big horsepower. Learn to f**king steer. McFly has 260rwkw, Z32 mike had just shy of 300 rwkw, Cadmoon has 180rwkw, Benno's S13 was running a stock RB20 with factory gear and they would all run after up Nebo, glorious or around LP faster than you.
Coilovers, sway bars, strut brace, decent tyres and learn how to use a clutch and steering wheel properly.
I don't want to hear any one else encouraging p platers to mod their cars in an illegal fashion. Yes, a 30 in a 33 is illegal. The motor wasn't an option and hence would require a blue plate.
Time and time again, the guys who've done it have said that it's not a great idea and have outlined the reasons why. If this doesn't suffice, contact someone else via pm. Colin had a pretty decent 32 and his advice is valid. If you want to play with the big boys, listen to the advice try give. If not, you will be a statistic and create more grief for the community as a whole.
This is a public forum and if you guys don't sort out your act, this page will be closed.
Im not trying nor will be doing anything illegal, I was putting together ideas and asking for a simple opinion I don't wanna cause a big uproar on the page so I'll just leave it at this and agree with you
I'm just doing a project motor. Just looking to do a solid build. Not sure on if it will be going in or not. I'm just doing research and getting ideas from past experience to see what it's like to do the motor side of it
Come time and I'm off my p's and I decide that I want to put it in and I have enough funds to afford it I might go down that ally if I want to try something new with my car
Or I could just rolling shell project it
Yes I acknowledge that me having a turbo on my p plates angers a few and other argue about it and that I shouldn't because of laws
But as I see it. I drive pretty safe I treat the car well I went about it all legal. It's not a flat capper camber hella flush crap thing I want is to look stock and I'm not modding it power wise untill off p plates to avoid a rear examination from tha police
But as I said engine will most likely be sold
The engine is for experience bad learning so I have physical not paper experience
That being said back to whoring I will keep future motor posts out of here
Yeah i dont get the uproar on this at all. The whole point of this place is for the younger guys to ask questions and learn from the people who have done it.
advice isnt gospel either and most of the time people do whatever the f**k they want anyway, i wouldnt stress that hard about it Tony.
Atleast when those questions get asked there is a bit of car talk going on in here even for the briefest of moments.
Threatening to close down the whore thread based on some chatter about a p plater wanting 400kw is a bit much.
  • Like 1
You're right. Its good to see the odd bit of car related talk going on in here.
I also think to generalize all P Platers as certain kind of drivers isnt the way to go about it. I bet there is a lot of P platers out there and even on this forum who are "better" drivers that fully licensed people.
not even for p's just gathering ideas so I can do some research and what not for a conversion when I'm legally allowed to convert into a turbo
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
