Mugabetown - Whoretownin' At It's Worst.
Stupid comment of the day goes to... Matt!
You don't need big horsepower. Learn to f**king steer. McFly has 260rwkw, Z32 mike had just shy of 300 rwkw, Cadmoon has 180rwkw, Benno's S13 was running a stock RB20 with factory gear and they would all run after up Nebo, glorious or around LP faster than you.
Coilovers, sway bars, strut brace, decent tyres and learn how to use a clutch and steering wheel properly.
I don't want to hear any one else encouraging p platers to mod their cars in an illegal fashion. Yes, a 30 in a 33 is illegal. The motor wasn't an option and hence would require a blue plate.
Time and time again, the guys who've done it have said that it's not a great idea and have outlined the reasons why. If this doesn't suffice, contact someone else via pm. Colin had a pretty decent 32 and his advice is valid. If you want to play with the big boys, listen to the advice try give. If not, you will be a statistic and create more grief for the community as a whole.
This is a public forum and if you guys don't sort out your act, this page will be closed.
Im not trying nor will be doing anything illegal, I was putting together ideas and asking for a simple opinion I don't wanna cause a big uproar on the page so I'll just leave it at this and agree with you
I'm just doing a project motor. Just looking to do a solid build. Not sure on if it will be going in or not. I'm just doing research and getting ideas from past experience to see what it's like to do the motor side of it
Come time and I'm off my p's and I decide that I want to put it in and I have enough funds to afford it I might go down that ally if I want to try something new with my car
Or I could just rolling shell project it
Yes I acknowledge that me having a turbo on my p plates angers a few and other argue about it and that I shouldn't because of laws
But as I see it. I drive pretty safe I treat the car well I went about it all legal. It's not a flat capper camber hella flush crap thing I want is to look stock and I'm not modding it power wise untill off p plates to avoid a rear examination from tha police
But as I said engine will most likely be sold
The engine is for experience bad learning so I have physical not paper experience
That being said back to whoring I will keep future motor posts out of here
Yeah i dont get the uproar on this at all. The whole point of this place is for the younger guys to ask questions and learn from the people who have done it.
advice isnt gospel either and most of the time people do whatever the f**k they want anyway, i wouldnt stress that hard about it Tony.
Atleast when those questions get asked there is a bit of car talk going on in here even for the briefest of moments.
Threatening to close down the whore thread based on some chatter about a p plater wanting 400kw is a bit much.
  • Like 1
You're right. Its good to see the odd bit of car related talk going on in here.
I also think to generalize all P Platers as certain kind of drivers isnt the way to go about it. I bet there is a lot of P platers out there and even on this forum who are "better" drivers that fully licensed people.
not even for p's just gathering ideas so I can do some research and what not for a conversion when I'm legally allowed to convert into a turbo
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
