Mugabetown - Whoretownin' At It's Worst.
I am going to go over it again tomorrow, all plugs are gaped @ .8 5 are bcpr7es and 1 is a bcpr7es-11 (gaped to .8) can't find a 6th bcpr7es anywhere up here.
I will inspect the coils again tomorrow as well as the loom.
I will swap the gaped down one out first and see if that fixes it.
You may not see it. You'll need to test them.
I have the factory coils here still, I can swap them in as they has no problems and have minimal K's on them.
I will do some testing and rule them out one way or another.
That's only like 10kg nick ;)
It's 12.5kg, I drop weight on the third set on bi cepts and do more reps usually have 15kgs on there. And I would put money on most of the people here not being able to curl it 10 times even on the first set.
I've been to gyms at resorts and shit and I swear there weight messurments are wrong there 15kg bells feel like 10 etc
eggszachary :)
Found best way to stop arking put silicone around the rubber tube that connects onto the body in that little space there and fixed it
u talkin bout a car or putting fake tits on yourself?
Seriously Nick, your talent is wasted in Gatton. You should definitely look into NIDA :yes:http://www.nida.edu.au/
Yer, mayb... I wouldn't call it talent as much as professional smart ass/shit stirer :P
I curl 16 with dumbells and 30 with barbells
I'm guessing your laughing at the part where I don't keep up with your capabilities? Haha
Well... if you say you curl reps at 16kg (which I'm not sure how you even obtained that weight [very odd number]) then well good for u.
If your forms good then that's a big achievement and something to be proud of.
just my
Gyms different and goes up weights in intervals of 2kg haha
Edited by Matty95
You forgot the weight of the bar
I can do that 10 times on every set, but not with my arms or legs lol
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
