Mugabetown - Whoretownin' At It's Worst.
Evening all
Zac is a top bloke, went down and found that I need:
Rear main seal
Top radiator hose - Got this thanks to Zac I will fit it when the car cools down.
Gearbox leak fixed - little leak @ the back.
Cold motor was the cause of the missfire I will run the factory coils until I cbf swapping the yellow jackets back in again.
nice :) where is he at?
Good to hear that the misfire is gone, but a leak? coolant?
Didn't stop me from having driving fun, was being gentle on the way home though.
Could of been really bad so big thanks to Zac.
Zac has saved the day! happy laps it is then?
So owners accepted our offer today. So i guess im a homeowner now :-D
Even better price we got it at means i can get another gtr!
Grats! and awesome! not another white 32 i assume?
Sup guys
howdy Mrs Cowdy
A bad...... Haha all good. Its still a paperweight at this stage anyway.
Can't wait to start getting some videos of it on song with gate and screamer in full effect
looking good man. that manifold, Is it welded to the original lower half? or bolt on?
Best ones at this place http://www.probolt-australia.com/
Legend! Ive been looking for a good bolt place for ages. thank you oh wise one
what? That shit happens in Gatton all D Time!
Here too....just generally with commondoors, and no where near as impressive.
First I got covered, but only on my full licence and when on a legally sanctioned race track ;)
paste the link with picture, I haven't figured out
I'm using the skyline Australia app so count tell you as I only pasted a link.. I think in a normal browser you have a option to insert YouTube video...
That's cause they think sitting on the brakes is cool...
    • Thanks, I'll shim that plug and hopefully it fixes it.  Yes still factory turbo for now, still have the misfire it's not as bad but still noticeable
    • I had someone check the CU, they said it was fine but it could be buggered  I was only running around 7-10 PSI on the dual stage controller, but my boost gauge is shit house and needs replacing so I'm not getting a true reading.  Then I ran from wastegate pressure as per Turbosmart but still have the same sort of issue
    • Yeah this is a thing. I've had mine setup like this for a few years now, works fine. If I dredge my memory bank, I think I had to do this after I removed my factory dash.  So you've tried it on gate pressure, I'm assuming this is the factory turbo? Did you still have misfire issues with that setup?
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
