Mugabetown - Whoretownin' At It's Worst.
Mornin.
why is it inaccurate?
They forgot to include my site loading
because Tax?
I hate when my boss puts in my double time as time and half
If only i worked in a job where tax differences could be $500 a week!
Mornin.
I paid more than 70f**king thousand dollars in tax last financial year. Got 2.5 back. Thieving pricks.
if u paid 70k in tax alone from a salary that means you are on a gross wage of $215,000 Mike.
Was just at All Star. R34 on a tow truck arrives with club sticker.
4sp auto box in it. Rego TTR34 from memory
Nice looking car. Had a dyno sheet from PITS of 430hp
Cool a Matty Spry tuned car eh!
interesting............
and complaining about only getting back 2.5k? damn that, gimme the 215k income anyday, the gov can have their 70k
You would consider it differently if it was you paying lots and getting nothing in return.
And you should therefore quit your bitching
Quit my bitching? Maybe when I stop paying for lazy dole bludgers, teen baby factories, and old people. I hate old people.
I worked hard to get where I am, to have the tax man take a fat chunk of my earnings. I could accept paying it IF the gov did something productive with it, or if I could choose where my tax $$$ went (combat vets, roads etc)
I have very similar complaints about the way my tax money is spent too (except the old people part). But I have no sympathy for someone earning as much as you. Get a better accountant and rort the system like all the other rich b*stards. :P
  • Like 1
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
