Mugabetown - Whoretownin' At It's Worst.
QLD has been quiet all day except for the hand full of key boards warriors causeing trouble from the safety of their computer screens
do you mean on the forum or just internet in General?
the amount of posts on the page haha
sorry my bad for not whorin tonite.
Been frantically trying to install windows 8.1 (full version)
Me and computers - we get along very rarely
Thnk thre is a few 25/30 projects going on now. I swear Matty is doing one along with you and I
I was going to once I got a skyline and probably will depending what I get but not gonna start until I have a car
Well anyways
It's pretty much I hold till I get the kesh to get parts and then I get it gets don't to machine shop then comes back and gets assembled
Did you update all your drivers BEFORE going to 8.1?
