Mugabetown - Whoretownin' At It's Worst.
Will swap 5zigen, Blitz Nur and a custom built ! .....was that yes ?
but seriously 'good work mate. Just keeps getting better - woot
ha! I still have my old zorst around including front pipes
Yeah it's taking time but it's gettin there
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
