Mugabetown - Whoretownin' At It's Worst.
Quiet day was quiet.
Drove past DOT and QPS setting up camp on the ramp to the M1 at Ormeu this morning. I casually cruised by while 6 of them all gave me the death stare.
makes you wonder how many import trophies they collected.....
Hai ants! Reply to my PM I sent you few days ago.
Or you're still too drunk to find it?
Hi Grant,
Sorry mate, I have no real excuses for not replying earlier :wacko:
PM replied now :yes:
Burnt exhaust valve, head has been sent away should be back in the coming days
should kick ass once its complete Scott.
Really need to find a nick name for your car something like the scotty-thirty :whistling:
Hey Scott, I'm building the 25 30 to lol. It's going alright, just a bit of talking and planning with dan from erd on the best way to go. Since talking my builds already doubled what I though it would. I have a fully built head with a lot of work done to it, just bought an npc twin plate clutch to handle 1000hp at the wheels. Getting under car surge tank made up in progress, working on getting harmonic balancer from Ross, but dan thinks I should look at getting the Ross trigger setup to, which is an extra $2000. So I'm not sure on that one yet, how did you go with your engine regards to timing at 4000 and 7000rpm? No jumping around or anything? And still deciding on oil pump, which will probably be a nitto pump, these are things I didn't plan on the 1st stage of the build but need all the above for balancing :(
I reckon everyone should have a crank trigger. There are cheaper ways to go though. Ask Dan about the set up in Noels car. The price ross charges is crazy.
  • Like 1
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
