Mugabetown - Whoretownin' At It's Worst.
So just won this fish tank. Kids are going to be happy
{style_image_url}/attachicon.gif 1384045714497.jpg
now u need fish and u also just made ur life that much more difficult lol
Skyline coolent boiled for 30 minutes this morning :( went to drop the car off at Chris' and just after we stopped the coolent boiled into the resevior and oil pressure dropped to nothing :( so sad
Sounds like a lemon..... radiator blocked??
ohhh no!!! Need that oil cooler hose. I will look up Nissan Fast
  • Like 1
yeah we need the hoses. it had a big air buddle in the engine and this was its first propper drive today. so we will fix it, it is at audio express getting an alarm atm on the way home we will stop every 10 or so minuets and take it slow to keep revs down.
  • Like 1
{style_image_url}/attachicon.gif ImageUploadedBySAU Community1384128296.207170.jpg
Bloody thing almost overheated on me... Just as I arrived at Chris'
yup very nice color midnight purple
  • Like 2
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
