Mugabetown - Whoretownin' At It's Worst.
Got my self a new exhaust today. HKS Priest, hopefully quiets things down a little.
This is what my car has.....very quiet. A bit flatulent at Idle (I'm sure the GTR won't be as bad). and if its anything like mine, front half is 3" rear is 3.5"
Good to hear it is quiet. Hopefully doesn't cut power too much. It is indeed 3 inch at the front and 3.5 at the back. Weird! You need the higher flow at the front not down the back.
  • Like 1
Add more boost
no it ain't......it's just right.
You sure as heck don't want to bring anymore
unwanted attention to yourself
Dosent seem loud at all, was about to say you've never heard it but you would of heard it after I gave it a boot full on the road up to QR when i left happy laps and at the drag day.
Side note: the ant eater is in for charity cruise right?
although I never got to hear the unicorn on full song......I never really thought it was too loud but sounded nice :)
It is 112db at idle. When sitting at home you can hear it coming for a solid minute before it gets home! Lol. Its just a straight pipe with a cheap cannon on the end so I always needed to do somthing about it. It was always going to cause me to get fisted by the law at some stage.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
