Mugabetown - Whoretownin' At It's Worst.
Being a typical Aussie batsman?
Sadly at this point that is very typical. It's really hard to win a test on the first day when batting but it's pretty easy to lose one. Our batsmen need to realise this.
Just found out today that departing flight from BNE has changed and basically f**ks everything up!
Have to leave 4hrs earlier in the morning, hence now I've had to reschedule with BCT, we have now an 8 hr wait in Singapore instead of 4, we are not allowed to take a stroller, had to pay $500 for not even what's going to be 2 month old baby that does not take a plane seat, and in addition to that we weren't notified of the change it was by chance that we found out about it by calling the agent.
WTF!!!
WTF!!!
Thas annoying to say the least!!!
yeah but traveling with young kids not so epic Mel
This is true... I don't even handle being in enclosed spaces with children for long let alone travelling with them...
WTF!!!
The joys of international travel eh?
Ive done a lot of intl travel in my time to date mate and used to like it..........
But now I hate it because it's always last minute issues that cause more inconvenience........add really young children and it's basically a hell of a trip!
I can imagine mate. Best of luck with it!
Good luck with the kids on the travels! I'm still learning that no matter how much you plan it will never go to plan with children. Mine are 3 and 2
He has a very nice Nur now, it will be worth checking out at the charity cruise!
But does it chuck skids? Lol
Yer I'll be floating around charity cruising being a social moth (I'm not pretty enough to be a butterfly :P )
Oh really? That's awesome!
Ya. Millennium Jade. It has been named the snot rocket.
No LSx, Nick will be disappoint :(
Haha poor Nick.
It Prolly doesn't skid real well. Very stock.
Y u talk about car like it's something good if it can't even skid... Y bunta WHYYYYY
Well to be fair if he dumped it in crappy suspension and ran 215 linglong tyres like you it can probably skid. :P
  • Like 1
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
