Mugabetown - Whoretownin' At It's Worst.
Mr Dan, what's going on with you mate? Haven't seen you around these parts for a while
Just cruisin. I'm attempting a more laid back approach to life these days.
Wife is literally moments from giving birth to our second child. So close, in fact, that if she called my name right now, I'd sprint into the next room....haha
Ah another little dan or danette about to enter the world lol, it's very strange you pop up ATM as tony and I were only talking about you yesterday *plays xfilea theme song*
I'm always around somewhere. More recently due to me selling my stuff but still doing some things on the side. Engines mainly
Well yes *strokes beard* that's actually what we were talking about... Do you have any experience with building ls motors? :)
Well, more accurately you'd need to ask 2 questions there:
1. Do I want any experience building LS motors?
2. Do you really need to build an LS motor?
Sean at EFI had those things almost scraping 800hp at the tyres with reliability not being an issue whatsoever
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
