Mugabetown - Whoretownin' At It's Worst.
About to service the gtr with nothi g morw than a 25 dollar socket set... desperate times ... prepare for some mcgyver like shit.. not joking I dont even have a screw driver
mate......next time come around my place and you can service GTR there
YAY Car is alive for now, drives fine on old CAS but seems a little off when boosting so will keep that to a minimum till repalcement CAS or new one. (please santa )
Plugs changed
Oil/filter changed
Fuel filter changed
multiple air leaks fixed
aac cleaned
looks like ill be attending the Charity Cruise again :D
  • Like 1
Rule 1 don't sell your tools
Rule 2 keep at least one toy ( be that motor bike/car/race car
THIS
currently thinking about selling the skyline for a Motorbike but then i'll miss you guys
Plugs changed
Oil/filter changed
Fuel filter changed
aac cleaned
Good on ya mate.
Really happy you can be driving it again without those previous issues.
Servicing done... all good I think sheared one bolt . :-/ and may have poured 200ml of oil before I realised that the sp plug wasnt in but ok really
for those that are interested
i used 1x 2nd hand socket set from cash converters $25
1x Ka bar combat knife $ had for years
2 x empty 2 lt coke bottles $0
1x 1.25 empty coke bottle cut in half $0(half for oil half for a funnel )
1x ikea flat pack allen key $0
2x XXXX gold
penrite oil $70
new filter $24
thats a gtr serviced for $120
Edited by ibrox90
  • Like 1
So anyone knoq where I can get a coil pack rail bolt from ???
are you talking about the little bolt that holds the coil back to the metal frame or the big bolts that hold the coil pack metal frame to the engine head?
I have got the coil pack bolts from supercheap before
    • Thanks, I'll shim that plug and hopefully it fixes it.  Yes still factory turbo for now, still have the misfire it's not as bad but still noticeable
    • I had someone check the CU, they said it was fine but it could be buggered  I was only running around 7-10 PSI on the dual stage controller, but my boost gauge is shit house and needs replacing so I'm not getting a true reading.  Then I ran from wastegate pressure as per Turbosmart but still have the same sort of issue
    • Yeah this is a thing. I've had mine setup like this for a few years now, works fine. If I dredge my memory bank, I think I had to do this after I removed my factory dash.  So you've tried it on gate pressure, I'm assuming this is the factory turbo? Did you still have misfire issues with that setup?
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
