Mugabetown - Whoretownin' At It's Worst.
It's the Swiss you don't f**k with......they have secret shit buried and hidden everywhere.
think u may be gettin confused with those Austrians that keep there so called missing daughter locked up in a secret panic room of their own house
theres a bit more to it than that ants.........like incest :P
lol, I was referring to military stuff, the number of very quiet looking airfields surrounded by mountains with air vents was interesting. I felt very safe driving thru there
as long as u stopped by to say hi to the cows you'd be fine lol
speaking of the french....or not at all.
Did you get your HKS zorst fitted? hows the noise?
i also want to know?
Not yet. Some other projects ate up last weekend. Cricket and yet more six around the course will kill this weekend so I will probably just leave it until the Christmas break
sadly theres no hall mark card for
" congratulations on escaping your austrian underground sex hell"
Well that may be the case, but I'm sure if you wrote a stern worded letter to them they may get something in the works
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
