Mugabetown - Whoretownin' At It's Worst.
It's the Swiss you don't f**k with......they have secret shit buried and hidden everywhere.
think u may be gettin confused with those Austrians that keep there so called missing daughter locked up in a secret panic room of their own house
theres a bit more to it than that ants.........like incest :P
lol, I was referring to military stuff, the number of very quiet looking airfields surrounded by mountains with air vents was interesting. I felt very safe driving thru there
as long as u stopped by to say hi to the cows you'd be fine lol
speaking of the french....or not at all.
Did you get your HKS zorst fitted? hows the noise?
i also want to know?
Not yet. Some other projects ate up last weekend. Cricket and yet more six around the course will kill this weekend so I will probably just leave it until the Christmas break
sadly theres no hall mark card for
" congratulations on escaping your austrian underground sex hell"
Well that may be the case, but I'm sure if you wrote a stern worded letter to them they may get something in the works
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
