Mugabetown - Whoretownin' At It's Worst.
Who wants to sponsor me? Want to buy a brand new CAS from Nissan. Really don't want to play the guessing game with another second hand one.
Gus Oberhardt on facebook was selling one a week or so ago. Few months old, I think he said 4. Wanted 400 bucks for it. The rb26 and 25 one are the same I think?
I have another second hand CAS lined up with cowdy.
Just hate the things as it will be the 4th CAS to go onto the car and would be easier to get a brand new one but at over $600 I won't be getting one anytime soon :(
4 CAS units? I suspect something else might be at play
I have had 3..
First one on the car died
Second Hand one never worked from when I got it but as I had other issues didn't know it was stuffed
Third one that was Second Hand reconditioned capped itself....
I guess it could be something causing them to died or fail where my car runs like crap.. I am back on the second CAS where I have a miasfire under 3k which is heaps better than the reconditioned unit
positive, swapped between CAS i have and both run differently the one i went back to and currently using runs the same it did before getting a newer one..
Sure it isnt the connectors?
Thinking about buying one of these http://www.ebay.com.au/itm/CRANK-ANGLE-SENSOR-NISSAN-Skyline-94-98-R33-2-5L-6CYL-J926-CAS-ONLY-RB25DET-CAS-/131008368517?pt=AU_Car_Parts_Accessories&hash=item1e80b50f85&_uhb=1
I thought my cas had died at one point, it was a faulty wire in the loom that needed to be cut back and replaced, worked flawlessly afterwards.
If the car changes between running fine and running funny while playing around with the cable you could have the same issue.
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
