Mugabetown - Whoretownin' At It's Worst.
That was last camp apparently there was like 6 in a pile
There in the scouts community but we are in what's called rovers.
Under us is venturers and they are 14-18
Then below that is scouts
Hey everyone :)
howdy :action-smiley-069:
I'm more shocked that 18-24 year olds are still in scouts?
this
And I'm just sitting here 22yrs old and not having any sex.
:domokun:
Sounds like not being in scouts was a mistake.
and this.
Understatement, and well done to em I say......dunno if i'll make it after the charity cruise.
I can see mass defect stations setup all around dreamworld that day.....totally random of coarse
If this is as big as they say and i believe it will be this will be up there with "jafs cruise in adlaide" 1000 plus cars
and thus totally worth a defect
Edited by ibrox90
Nothing is worth a defect.
Not even especially reach arounds from Tony.
You love it.
Also, planning a Golf Day. Just casually with a few guys playing ambrose. Open to suggestions on locations and dates. At this stage, thinking 22nd or so. Midday/1pm tee off.
Non-negotiables are:
Beer
Buggies
Scott, any recommendations?
You love it.
Beer
Buggies
Why not stroke play? :P
1.5-2k with all interior don't care about engine or gearbox have one lined up
$2k? With all the interior? For a rolling shell?
Seriously?!
Mikes selling a z32 rolling shell. Ask him if he'd part with it for $2k.
I don't care if the paints shit and there isn't an engine and gearbox in it I just want a cheap straight shell to have for project I have an rb25det engine lined up for a rebuild
Rolling shell for 2k is a lot man you can get a 31 in close to roadworthy for 2k
1k for rolling shell is around the right area
As I said Matt hit up all the places I told you, I also forgot about boost cruising
They sell rolling shells like no tomorrow
Especially the 32 and 33's
