Mugabetown - Whoretownin' At It's Worst.
I joined for all the free stuff.
P.S. still waiting on my free stuff o.O
As soon as everything is in I'll send out all your member freebies. :) Can't send stuff I don't have unfortunately.
We've just gone through a rebranding excercise with new logos and stuff. We're still waiting to get a lot of items finalised and then send member packs out. Should all be ready by the new year for membership renewals :D
I'd be leaning towards the Galaxy personally. my nokia (720) is a good phone, but it shits me to tears every time i find an app i want only to see "IOS and andriod" only. Eg, remote wifi control of my camera.
Yeah. I'm going for the samsung. Couple of others in the office are going iPhone and one other is going for the lumia. Preference for them was a smart phone with an awesome camera. :P
I don't really get that angle.
Sure, you have a really good image sensor, and they're making some nice lenses to pack into such a thin space.... but you still won't beat a camera with a decent sized zoomable lens. 300 bucks gets you a camera with a 1-20x zoom, and a great image sensor that fits in your pocket, and you can still have your normal smartphone camera if you spot something nice along the way
She's got two kids and a nappy bag etc to carry around. Having it all in one makes life easier. Windows 8 isn't too bad to use either.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
