Mugabetown - Whoretownin' At It's Worst.
It's .7 of an inch bigger than a s4. I am so cut that Anna got a replacement phone only days before they launched. I could have had a note she could have had my s4. As it's stands I am probably going to have to buy a tablet for work now in addition to my phone that can alllllllmost do the job. So annoying >_>
I've got an android 7" tablet set up for something a little different. Will show you at CC. How's Anna going with everything?
http://m.brisbanetimes.com.au/queensland/car-enthusiasts-to-remember-paul-walker-with-charity-drive-20131203-2yooc.html
Thia will be more epic... I reckon at this will be bigger than jafs cruise in adelaide
Where the fuark is our mention for Charity Cruise?!
Nothing to do with a famous dead person just unfortunate children and obviously media don't care.
So I am guessing Saturday,
As Sunday is happy laps,
speaking of which any of you guys going ?
Ill stick my nose in as its just round the corner from my place buuuut the gtr wont be on the track
More interesting is that article about which roads are up for a review of their speed limits. Notably, my Nebo and most of the highways in seq. Report due mid next year, will be interesting to see what happens
  • Like 1
