Mugabetown - Whoretownin' At It's Worst.
So my day is made. I went for a ride in schrodinger.
This guy!!!. Finally back in my possession. Thanks again Clint for the help with picking the car up. Hope you enjoyed being the first to ride shotgun.... I hope my driving wasn't too poor
th_0d23b03620eb103951d401b2a99c60b1_zpsa#RandomHero83#RandomHero83
  • Like 2
More than welcome mate, The driving was fine.
uneventful trip?
lots of looks of surprise on motorists faces
Ran like a dream the whole way..
sounds like a nightmare, It will scare small children...I love it
This guy!!!. Finally back in my possession. Thanks again Clint for the help with picking the car up. Hope you enjoyed being the first to ride shotgun.... I hope my driving wasn't too poorth_0d23b03620eb103951d401b2a99c60b1_zpsa#RandomHero83#RandomHero83
so happy for you mate. What was the end result poawa wise?
Hey Mr Ants! How goes the travels?
too long man......to damn effin long
But I'm here now completely jet lagged but pushin through it
Will be goin for walk soon to get some very fresh air to keep me awake so I can get into the time zone ASAP
Hope things are well in this part of Qld
You'll be right. Get some vodka in to you and take the kids out. :)
When do you return?
512hp on 18psi, rich reckons the gearbox will let go if we wind the boost up to where I want it. Still so so much more in this thing. Torque is very interesting.
Sawft! 36 psi is where the real bad asses are. :P
That's f**king awesome dude!! Well done :)
When do you return?
the 6 of Jan so not too long
Yeah the Fins man........they can firkin drink eh!
Finlandia vodka anyone ;)
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
