Mugabetown - Whoretownin' At It's Worst.
Isn't Europe fun!
Boz. that sucks, I would assume heater hose
GT6 installing now.....seeyas some time in the future (and sunday)
yes hence y I love it so much :)
Also noice re GT6
been awake, missus got me up with the promise of some nookie,
only to tell me to do the dishes and clean the lounge ........
WTF is this false hope shit !!!!!
That is BS! There are few things in life better than waking up to a morning gobble.
Nor looking forward to cleaning the car today gonna pull half the car apart to fix up some trim that hasn't been sitting properly for a while now.
At least your cars are able to run :-P
Anyone got a spare seat for a photographer I've got coming along? Work and the car gods have f**ked me over. I can get him to the meet (in my oh so classy Astra) but I have to bail early so he'll need a lift to the powerhouse mid afternoon.
just evil that is just evil.......
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
