Mugabetown - Whoretownin' At It's Worst.
Mr Scott come drink dirty dirty martins with me...
Ie, gin and ice lol
Sorry nick me no drinks much these days...
and then one of these comes along...
Lol'd hard at this... I'm still so undecided on my gear box option
Sideways 60 metres prior to bend will fix that Pete :)
Nick I used a turbo 400 in my pro street 500ci 14/71 Bronco - it was rock solid never broke Neal Trans built.
^ this guy he speaketh my language lol
I'm Having nothing but issues with my 4L60e spent a fortune on it and it's still being gay
Hmm I guess, mines pretty doughy off cam ie anything under 4k... Although I spin the sum bitch up 7k now so yeah. But coming onto the highway at from 60 if I tramp first and ratchet second it basically powerskids around the shop easily to 100.
But what im getting at is people around the place claim there bulk hp cars are "streetable" yet I can't see how it's possible... Some insight from a guy/girl with a big powah street car is appreciated
My daily had 390 kw , it was perfectly streetable unless you wanted to zip around someone on a roundabout, where it would rather go sideways if shown boost than accelerate out infront of them.
Spending some money on decent rubber is a must.
Morning all, first day back at work :(
@Nick: Tyre quality is a lot more important than tyre width. 235 shitty Chinese tyres will still suck, so will 255, 275, etc.
But a good quality tyre the same width will provide a lot more grip
this, a whole lot of this. P zeros!
and again
I need to experience this "boost" I don understand it
indeed
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
