Mugabetown - Whoretownin' At It's Worst.
good on ya mate. I like the positive energy your demonstrating. Keep it up and I'm certain good things will come your way
Thanks mate. Hoping so. Need to just get in, get my hands dirty and get the job done. Have had chats with the team members and their all loving it. The fact that I don't fuark around, just do what needs to be done, communicate requirements and expectations easily and what not. They've all said that I haven't even been managing, just setting expectations and communicating them effectively which has essentially been perceived as facilitation as opposed to management. Meh, they like it. Work gets done. I'm not complaining. Hopefully I can actually move into a leadership role and more importantly earn leadership kesh monies :P
So who's pumped for the happy laps ?????????
Pick the GTR up tomorrow morn gets dyno'd tonight to see if I make more power with some minor adjustments,
Most of all my ECU issues should be all sorted.
what HP / kW are you expecting the R35 to make bubs?
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
