Mugabetown - Whoretownin' At It's Worst.
Neg. There is not enough money in the world for me to be responsible for this bunch of weirdos on a permanent basis!
Lol! Small team at present and if I get my way, I'll have a far greater say in hiring and firing. Already have a pretty strong say in hiring.
Our team is only 22. But the mix of personalities is crazy. Every day is some form of psychotic episode. If there was more scope for disciplinary action it would be ok. But government is gonna government.
Prob wont make much of a difference if any so I be happy with its 557 awhp it already made,
but if more ponies decide to join the herd, then hey I will welcome them with open arms :w00t:
nice mate.
