Mugabetown - Whoretownin' At It's Worst.
I drove around Gatton all day today. Not one Captain Natro was seen
But I was in town like all day? How could u miss me... I literally was down town 5 times today between the hours of 5am and 7pm :(
Side note finished at 1 we could of got a beer
Just pulling your leg man. I was there pickling my mum up from hospital and helping her out with shopping and stuff so I couldn't really do beer. Next time!
You were doing what to your poor mother!?
Also u said next time last time lol
Also I has harassing around your brothers workshop yesterday fixing my vibration :P
He did mention an orange heap o shit. .. :P
