Mugabetown - Whoretownin' At It's Worst.
I almost bought a lm when I got my GTR. But at the end of the day it was just a blue boat with no mods, so I bought the pos unicorn instead
same running gear........xcept one floats on water and the other makes rainbows when flying :P
True! Though this LM was pretty much stock where as the uni already had after market turbos and such
OH and the LM had that sill active rear diff, where as the Uni has good old mechanical
Edited by Bunta
Want to punch this cocky little weasel at work in the face, f**k me he's the f**kin slipperiest prick I've ever met.
Pity he's the head bosses son, skinny little f**k. I'd love to see how quickly he'd shut up if daddy wasn't here, jam his head in a car door
woah dude! take it easy man.
long weekend is not too far away.
in the mean time just ignore the rodent as much as you kan.
Mmm... Just over today so that's not helping. Storm last night f**ked all this shit up, an. Now we've got electricians and shit floating around the joint (also I'm at shell not the bakery for those playing at home)
sux bro.
tits will give ya shirtless man hugs for ya.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
