Mugabetown - Whoretownin' At It's Worst.
Yeah well considering we wanted we to buy a cheapo BBQ from Kmart and ended up buying one costing 1100% more........
So we are going to make sure we use it as much as we can!
clean it on next use, grease stops plates from rusting
thanks for the tip Bodo. This BBQ has aluminum grills so won't rust.
I have an iron plate but will use it next time.
Think I will clean the BBQ on next use too
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
